rear panel 6x9s - changing?
Results 1 to 3 of 3
    mgemie
    I'm due to replace my factory-fitted rear 6x9s in the side panels sometime at the weekend...how many plastic panels clips will i need to order to replace those i'll break when removing the interior trim?
    Streamlined Sponsor Burple's Avatar
    Jul 2003
    Can see my house from up here!
    Full on JCW!! :)
    7,459
    Hopefully none!!!
    We (myself and Zimbo) did both of ours without managing to break any....
    You know you don't need to take the whole back seat out if you're hands aren't gigantic...
    Just remove the rubber door trim, and pull the panel back down to the floor, and about three quarters of the way back along the top of the panel. This should alow you enough room to be able to get in to take the speakers out and enough room to be able to get a reasonable sized screwdriver in for the job too.
    Unless the trim clips fall out, you might get away without replacing any, although we had a few spare ones just in case...
    The wiring is pretty easy to work out too from a head unit - but you might need to pull it out a bit to check the colours on the HU side to match 'em up!
    Trim Clips There Made Of Better Stuff nowadays, Unless your car is an Early Y Plate..then I wouldn't bother Ordering Some.. But there usually all alright.. And Top tip There Euan... All teh Best With The Mod..
    If your Doing the Ft as well You Have to Get Violent With it.. there is no Other way...
    Good Luck... Use The Force.... ( Sorry Couldn't help it)
  1. How to remove a door panel?
    By vintageb3 in forum Interior & Steering
    Last Post: 17th March 2007, 12:23 AM
  2. Boost Gauge panel...
    By DJBlack in forum Engine & Gearbox
    Last Post: 22nd August 2006, 03:28 AM
  3. rear 6x9s suckin all da'juice?
    By mgemie in forum Engine & Gearbox
    Last Post: 25th November 2004, 09:59 AM
  4. best spec of 6x9s?
    Last Post: 30th September 2004, 11:58 PM
  5. 6x9s
    By aimee_s in forum Engine & Gearbox
    Last Post: 13th September 2004, 06:49 AM
