Vanos sensor issue. Ongoing.
Results 1 to 10 of 20
    Single-handedly bankrupting eBay Ferengo's Avatar
    Jul 2008
    Dundee
    F56 JCW Cooper S
    1,294
    hi guys. Not been on here in ages. Have a question.
    I have an R56 Mini Cooper. I get a fault with the engine management light. I've been told by my local garage it was probably the Vanos sensor. While my wife was away the sensor came on again. She took it to the local mini garage where she was. They tested it and replaced the oxygen sensor. It was on the receipt as oxygen sensor M11.78.7.590.713 037754/PROBE.
    Anyway, that was back in April, the warning light has come on again. It went into my local garage who said it was the sensor again. They reset it but said it might come on again and that they'd have to get someone in to specially reset it as the values may not have been reset when it was done by the mini garage in April. The words they used were "it may still have the old values".
    What I want to know is 1. was the part that was replaced by mini back in april the vanos sensor. 2. If it was and they should have reset the values, should I take it back into them and ask for it to be done for free rather than having my local garage do it and charge me? 3. How long do mini warranty their parts for?
    I should point out that there's no way we can take it back to the Mini garage it went to in April as it's too far away, it would have to go to my local Mini garage.
    Hope that all makes sense but post below if it doesn't and I try to clarify.
    Oh, I also have all the receipts from back in April if need be.
    Thanks, G.
    If it was me I'd personally take it to the local MINI garage with the receipt and explain the issue.
    Yes they should've have reset the values if that was is required after fitting the part.
    OEM parts are usually warrantied for 1 year but some parts can carry a 2 year warranty.
    The only issue may be is that there are two O2 sensors (in the exhaust) and it could be that the other sensor has now failed. You'd need to know which one they replaced pre or post cat ...
    Hope this helps ...
    F56 JCW GP, R55 Clubvan
    11,691
    As above
    Jul 2008
    Dundee
    F56 JCW Cooper S
    1,294
    I'll give mini a call tomorrow and find out what part was replaced and also the garage as to which sensor it was. If it is the same sensor then I'll take it in. Thanks for the help guys. I'll post up what happens.
    4,249
    Keep us up to date ,good to know the outcome . From reading your post does not sound like they replaced the vanos sensor ,but as stated by Davie there are 2 sensors pre and post cat ,the main issue is was it a faulty sensor or something else to bring on CEL light Eg faulty Cat ? And if it was a faulty sensor has the other sensor now failed ,what year and mileage are on car ?
    Jul 2008
    Dundee
    F56 JCW Cooper S
    1,294
    Hi.
    Agree. I went to my local garage this morning with the work sheets and they confirmed that it was not the vanos sensor that had been replaced and it was pre cat oxygen sensor that was replaced.
    So the issue now is the vanos sensor again and it looks like it might need replaced. They're going to speak to someone who has experience of the issues with them to see if anything can be done before replacing it as I was quoted around 400-500 for it to be replaced around 6-7 months ago. Does that sound about the right price?
    The car is a 2007 mini cooper with around 55000 on the clock give or take a couple of thousand. Always been serviced when needed.
    JCW Upgrade JOHN MILNE's Avatar
    Mar 2008
    PRESTONPANS
    F56 MINI COOPER S Thunder grey
    623
    the vanos sensor part number is 11 36 8 610 388
    as i have repalced one one ny car
    ther are two fitted one on front of cylinder head for exhaust
    one at back for inlet
    F56 MINI Cooper S, thunder grey, john cooper works body kit colour coded jcw pro front splitters Maxton design roof spoiler extensions, JCW rear bumper diffuser, wheel arches side skirts, fuel cap, heads up display, black door handles headlamp and tail light trims, ac schnitzer front splitter maxton design side skirt extensions, ultra racing strut brace
    Jul 2008
    Dundee
    F56 JCW Cooper S
    1,294
    Thanks John.
    Was it a big or long job to replace it? Also how much was the sensor if you don't mind me asking (PM me if you want to)?
    Thanks, G.
    Thought it'd be an O2 sensor they're prone to going .. If the pre cat one has been replaced the post one won't be far from going either they always seem to go in pairs !
    You'll get a new non OEM vanos sensor for £95
    There are two soleniods fitted to the car, inlet and exhaust, both are the same so you'll need to know which one has the fault. Once the new one has been the car will require programming.
    I'm not too sure what's involved in the job but given if you can supply the part I doubt labour would be near your quoted figure.
    Do you get Fault codes P0014, P0011, P11A8 or anti pollution display, ecu coming on when it's scanned for faults ?
    You beat me to it .. Maybe John can tell you how much the job cost (part/labour) ?
