Yep no prob I will have stock with me Will go thro fitting on Sunday with you :) 👍
David yours is leaving to day been run off my feet at work but it will go today
Pm'd.
noise is worth bhp
Back at ya
cheers Stoney item arrived today thank you now how do you fit it?
Sent you a PM but I will do a how to at some point soon
Simple .. Clean the chrome strips with a cleaner fluid and ensure that they are also dust free.
Best to try and fit the belt lines in a garage if possible.
Starting at one end slowly line up the top edge of the chrome with the top of the belt line then slowly work your way along the chrome strip lightly pressing the line down with a microfibre cloth or similar.
Once you have completed the full strip, trim the excess off and then slowly heat the line with a hair dryer and smooth it down gently. Once you've done one strip move onto the next. Hope this helps get you started ...
Any problems if you're near to me just shout and I'll give you a hand ...
