I actually went down the cheaper B&Q route and its six years old. Name means nothing as I don’t think B&Q sell them but it was a Mac washer. The trigger sticks on sometimes but that’s it. At 110 Bar it is strong enough for me.
Because of the fitment with my foam lance if it does grind to a halt then it’s a Bosch as they share the same fitment.
You don’t want a big heavy lump anyway so your probably looking at the smaller washers. Like most things there is good and bad reviews for every make. If you want the foam lance I’d make sure there was a fitment for it.
Karcher, Nilfisk, Bosch will take a foam lance with the right fitment.
The guys selling the Foam lances usually know what fitment is needed for example a Halfords HP2800 pressure washer needs the 'Kranzle' adaptor. As for power I think anything over 110 Bar is fine but I’d not want to go too far above that if you ask me. For home use around 120 bar I think would be fine.
I have the older Model of this...
autobrite-heavy-duty-foam-lance-various-connectors.html
