You can bump start them. You have to have the key in and the ignition fully on. It will come up with an exclamation mark on the rev counter and will beeb at you.
Presume your USA mini is a manual then if you are wanting to bump start it. If so slip it into 2nd as 1st puts too much resistance on it and its sometimes not enough to spin the engine over enough.
