Went to move the mini so i can get out the drive easy in the morning cause i'm off on a long trip and the engine wont crank.
Put the key in the slot, depress the clutch, press the stop start button and only the ignition comes on, the starter does not make any attempt to start the car
Frikkin typical, first time i've actually "needed" the car and it wont start, anyone had the same issues??
