I have just had me radiatior replaced. Before it was replaced my interior blower and a/c blew only warm not hot air and no cold. After the radiator being replaced it blows hot air on the hot setting but on cold it feels warm. With the a/c on the hot is hot but the lo/cold is not icy/cold like it used to be. Could it be the a/c needs re-charged and it is just cocinence that it had failed at the same time as the coolant radiator? Any advice appreciated, thanks.
Depending on why your radiator failed can impact your A/C, it sits directly in front of the normal radiator so if something hit it then that's likely the cause.
Happened to me once when i hit a bird traveling to see mikeythemini, had to replace the A/C rad and it wasn't cheap
Thought it might need recharged. Had a mechanic look at it today he said the same. Leak test and recharge £40. Will try the stealers too for a price. Thanks.
