Spax Coilovers fitted, now have driveshaft vibration!?
Page 2 of 3 FirstFirst 123 LastLast
Results 11 to 20 of 21
    GCA3N
    Wanted to see this as I thought it may look daft. However it does look good, think however you are going to have to go back up a bit. Trial and error raise it up a bit, go out and test it, see if the fault dissapears.
    Harry Fairbairn Sponsor
    Aug 2006
    BRIDGE OF WEIR, United Kingdom
    1,108
    Just one of those unfortunate things... Mine was dropped as low as that on KW Variant 1 Coilovers and i suffered the oh so common vibration problem... Its linked to your CV Joints, because they are sitting at a new angle outwith there normal operational.. you may be lucky and they will eventually work in a new groove and your vibrations may be gone. I have heard that vibrations have disappeared over time on a few cars as a result of this...
    I ran mine for 6 months but never really got rid of the vibrations until i raised it back up to an acceptable height... The only thing i can suggest is to try raise it slightly ie 3/4/5mm at a time and road test and see and if your still getting vibrations.. If so raise a bit more and road test.. You will eventually find a happy medium and vibrations will be gone (normally around 30mm).. I had to raise mine to approx a 40mm drop to overcome it and car still sat very low...
    I eventually got rid of mine as the high offset of the JCW R105 48et wheels wore right through my front spring perches and on the inside of the wheel and wrecked my inner rims... still got a bit of catching after fitting 5mm Eibach Spacers.... So off they went to be replaced by my current JCW Suspension set up which i love albeit that the car is only lowered by 10mm now...
    The other thing to note when running your car that low is the massive negative camber on the back.. My rear tyres lasted a mere 5 months and were worn right through on the inner edge... I would advise on adjustable rear control arms to prevent this... Alta or Eibach variants are very good...
    I loved my car slammed and yours looks good too its just a shame that some MINIs and it is just limited to some suffer from these Vibrations..
    Good Luck and hopefully this has helped a little
    Feb 2003
    Pensacola
    R56 FJCW
    17,231
    I doubt your handling will be as good as the factory setting, 60mm is, in my opinion too far to drop, but, if it's looks your after, then that's your choice.
    Big Brake Kit zimbo's Avatar
    Jul 2003
    Planet earth...
    4,380
    Well in the long run if you keep running your car at that height and with the vibrations due to the ride height then your just going to end up destroying both your driveshafts and all your CV joints!!! So i would recommend raising it up till you no longer have the vibrations.
    Gaz-Muir
    Im going to lift it 10mm and see how it is. Ive had a look at the driveshaft angles and they dont look that bad. Ive certainly had cars with much worse with no problems at all..
    So it is a known of problem, that when theyre low they may get a vibration??
    Gaz-Muir
    Quote Originally Posted by Ivano View Post
    Thanks mate, i have 5mm spacers fitted too as the wheels were just catching the coilover and no more.
    Ill also be getting the rear camber sorted out!
    Aug 2006
    1,108
    Quote Originally Posted by Gaz-Muir View Post
    And saying that most of the guys in the States run their cars crazy low and have no vibrations...
    Johnleiper
    i ran my spax suuuuper duuuper low as low and had no vibrations. just luck id say.. the strut tops did start to "bow" tho so extra bracing is often a good idea
    Gaz-Muir
    Its almost ne now, and i havent done anything!
  10. #20
    Mini Mad countdown's Avatar
    Sep 2008
    East Kilbride
    Cooper S
    133
    Doesnt look excessively low to me, about a 50mm drop. Still not sure what the issue is, doubt it is to do with the angle of the driveshafts though. maybe damaged a driveshaft when fitting them? are your sure the vibration is coming from the driveshaft?
