Copper slip or Molly paste will do .....I'll bring some onshore if you want Martin....pick up at The house of Sully ..(10th Jan )
Co-Efficient Of Friction......
Don't get me started.....
supposed to be non work related forum..
But simply. The first few Posts are correct. Slight smear will do the job.. and You CAN OVER Torque the Wheel studds if you use to much Copper or Molly slip....
take that as a warning
Good tip, If wheel is tight to come off of hub. Boil your tea pot with water then poor it over hub. Wheel comes right off with no effort. Nice we trick when stuck. I use alittle bit of grease on bolts and hub to keep it fresh.
