Cleaning The JCW Alcantara Steering Wheel
Hi Guys,
I thought I'd share a little something I did this morning with a spare 15 minutes I had. My steering wheel has picked up a lot of dirt and grime and is looking a little worn. Alcantara can be a little tricky to maintain but here is some tips.
The patient -
http://i1049.photobucket.com/albums/...psfqenyyff.jpg
As you can see the Alcantara is matted. All the fibres are flattened and being held down by grime and oils.
As Alcantara is one of the most sensitive materials used in the manufacture of vehicles I thoroughly recommend you purchase a mild Alcantara specific product. My favourite by far is the Colourlock Sensitive Textile Cleaner which is gentle but effective but also low foaming, which means, there is no need for any heavy extraction or need for additional water which can have an adverse effect on Alcantara.
http://i1049.photobucket.com/albums/...psmaedesnp.jpg
I start by lightly misting the product over the Alcantara surfaces and allowing a 2-3 minute dwell so the cleaners can get to work breaking down the grime and oils. This is then lightly agitated by a soft brush. There is no need for any stiff scrubbing brushes, this will only wear the material.
http://i1049.photobucket.com/albums/...psuhe5cers.jpg
I then wrap a clean microfiber towel around the wheel and in an action as to rev a motorbike with light pressure, I work my way around the wheel to soak up the product and pull out the dirt.
Gross...
http://i1049.photobucket.com/albums/...pskix93dtb.jpg
This is followed up by another clean microfiber towel in the same action to dry the material.
The result, a clean, non-matted steering wheel that feels brand new!
http://i1049.photobucket.com/albums/...ps31t78wn9.jpg
http://i1049.photobucket.com/albums/...ps9plylgbq.jpg
http://i1049.photobucket.com/albums/...psyydrpzuh.jpg
With the gentle cleaning ability of the Colourlock solution, this can be used regularly to clean Alcantara. I would avoid any heavy cleaning solutions that are not Alcantara specific, It is a super sensitive material and the risk of damage is great.
Thanks for reading :thumbs up:
Bryce
Devilish Detailing
